Is this brake actuator salvagable?
Don’t worry about the brakes until you get home.. just make sure the reservoir is full. What is your tow vehicle?
But good deal on talking the grease gun with marine grease in it.. make sure it is full and possibly take another tube of grease.. that way you will not need it. So this is a “brand new boat” or used new to you boat?
If you do not have a heat gun get one and keep tabs on the hub temps..
I have a 2015 Hemi Ram 1500. I've towed 6500 lbs before and it's rated for 8000. I also have some heavy duty air bags installed that I will pump up to level things out. I believe boat and trailer is around 5000 lbs.
This is a 2024 but never been titled and a good deal cheaper than the one I can literally walk to at the boat dealer near me. 0 hours at least until they install batteries and water test it.
