Looks like a dock line to me. Those things are pretty thick.Best of luck with the repair. How much water did you take in afterwards?...and just out of curiosity what kind of rope is that? Wow
Yep doc line. Used to be 20ft now about 5ft.
@Volffas It was mine, we had the tube tied to the back of the boat with it. my kido un tied the tube and didnt put the rope in the boat, it was tied to the oh shit handle behind the driver. Wife cranked up the boat to push it up on the beach more, didnt realise rope was there and the rest is history. I want to make a alarm that goes off when you turn on the key and before cranking that yells ROPE ROPE ROPE.![]()
X2It can happen to anyone at anytime! We had a really close call this weekend. I think your alarm would be a great addition to my boat!
I defer to your first hand experience, I thought there was a (main) bearing in there. All this time people thought the weak point was a plastic through hull scupper when in reality they should probably be more concerned with the reliability of a short rubber tube and the clamps used to hold it in place. At the same time that part rarely sees the light of day but the scupper is out in the open. Again, good luck getting it fixed hopefully before your season ends.@Ronnie the through hull fitting that busted does not even touch the shaft, the rubber hose is what makes it all water tight. When I get my part in I'll share somemore pics.
The engines don't really make much horsepower (edit: I meant torque) at idle so the tension of the rope wrapped on the shaft caused them to stall. Like when you don't give it enough gas while you slip the clutch to get a standard transmission vehicle moving.Had a close call this weekend. Asked the kids if they had the ropes secured..."yes"... Wife started the starboard engine to nudge us forward....
Engine quit almost immediately. I went to helm to investigate. It quit again immediately. Tried the port engine. Same thing.
Checked the ropes. Gave the kids my "this is not a cruise. you are the crew speech". Popped the plugs and found ropes around BOTH shafts.
Here is my question/comment. Why did the engines shut down on their own? Is there some sort of switch that does/could/should sense the extra resistance of something like a rope in there? Is that a feature or just a convenient disruption in the normal operation of the engine?
Anyway, I popped the plugs and pulled the ropes out with only a little effort and cussing and untangling. No need to get in the water, etc.
No other damage that I could see, hear or feel. We ran the boat all day after that with no trouble.
Good luck to the original poster on your repairs.
