Wheelspin
It's pretty meager. Amp is the Wet Sounds HTX4. (DSP)The speakers are 25w RMS Jensen MS650s. So they've got a 400W RMS (100x4 @4ohm) amp driving 150w RMS worth of speakers total. Or, taken another way, $650 worth of amp driving about $125 worth of speakers total. DSP must be seriously cutting the gain to keep from smoking the little plastic fantastics.
I can also see from equalizing the input and observing the output the DSP has pretty much entirely cut off everything from about 80 hz and below. I haven't chased wires back yet to see if perhaps some are wired in series as well to lower the output. It wouldn't surprise me.
The end result is that it can put out an acceptable volume. It would play loud enough to hear ok even at speed I think. But it's very compressed. If horribly compressed Sirius satellite audio through an economy car stereo is not annoying to you, this will probably work just fine. Think music playing through an Amazon Echo sound quality.
