fireflymedic
 - Bonifay, Florida
Do the tabs alow you to plane at a slower speed
Yes, I can plane as low as 14 using the tabs. I find this useful on busy nights on the lake. I can go slow while maintaining visibility.
Late spring I sucked a large piece of plastic into one of the jets that I was unable to free via the cleanout plug. I had to boat perhaps six miles back to the ramp on one engine. I left the disabled engine at idle and ran the other at full throttle. The boat maxed around 13 mph. When I engaged the trim tabs I was able to plane out and run 18.
@Bruce - I'm talking to Kyle at Lectrotab and he is recommending the 12x9 tabs for my 2015 242. I have a very limited knowledge on tabs... what would be a noticeable performance difference between the 12" wide and 9" wide tabs?
He is suggesting the 12x9 to avoid contact with my transom straps. Thank you for any info - I greatly appreciate it.
I suspect what he is suggesting is 12" wide by 9" long? My tabs stop just at the transom straps.
If you look at the first post in this thread you can see that my tabs started as 12x12 but the outside edges were bent down making them closer to 9" wide at the trailing end.
I made mock ups of the tabs and actuators from cardboard and duct tape. Then I gave the measurements to Lectrotab who built exactly what I wanted. I am not aware of anyone having trim tabs on a 2015+ 240 so I would want to repeat that mock up process to get the best fitting tabs possible.
@Bruce - Will do. I looked through your install and noticed you mention shims but never anything about a brace or support for anything. Using the tabs do you suggest a brace or backing for the tabs or the actuator mount?
I need to look at it again to confirm 100% but I believe when it came time to install I was able to rotate the actuator sufficiently that I did not need shims.
Mine are screwed (not bolted) directly to the hull with 3M 5200 permanently sealing around the screws. Most likely I would need to drill the screw heads off I were to try to remove the tabs.
My experience is that the sides of my 2007 hull are thicker than the 2010 to 2014 series and even more so than the 2015+ series. When you drill a hole for the first screw it would be a good idea to check how thick the hull is in that area. If it is exceptionally thin you may want want to use something to build up the inside. I did not need to do so.
I was able to feel inside the swim deck portion of the my boat and found that I could install actuators into the same reinforced area as the transom strap U Bolts. That area is perhaps 3/4" thick.
Effing awesome!!!
