smthng
- Fruit Cove, FL 32259
- X
... I do this to both sides then drop the tower which will JUST fit inside the bottom rear loosened knob and rest the tower on a cushioned spacer...
I feel for ya if you have to do that every time you leave or return from your ramp/dock. That would suck... a lot. Fortunately, I only have to worry about storing mine when I get home. Following your method, do you think I could get the last knob out with the tower down? That would make my process at home a lot easier.
Regardless, if you come up with a better method of handling this critter, add me to the seriously interested column.
 Anything you come up with, I'll be happy to test to see if it works with the '08-'12 models (which doesn't mean I'm fishing for a freebie).  I'm not sure if there are any differences in the '13 and '14s.
 Yeah I can't speak for sure towards previous model years of the 212X or any of the other Yamaha models but I suspect that this modification would still work based on what you described on yours still.  To answer your question about the center section.. yes I leave it down and you can re-tighten the knob if you choose but I don't see the need to.  Also you brought up something I forgot to mention, I have added a small clear adhesive bumper to protect the  coating when rotated back.
