smthng
- Fruit Cove, FL 32259
- X
I feel for ya if you have to do that every time you leave or return from your ramp/dock. That would suck... a lot. Fortunately, I only have to worry about storing mine when I get home. Following your method, do you think I could get the last knob out with the tower down? That would make my process at home a lot easier.... I do this to both sides then drop the tower which will JUST fit inside the bottom rear loosened knob and rest the tower on a cushioned spacer...
Regardless, if you come up with a better method of handling this critter, add me to the seriously interested column. Anything you come up with, I'll be happy to test to see if it works with the '08-'12 models (which doesn't mean I'm fishing for a freebie). I'm not sure if there are any differences in the '13 and '14s.
