LS2000 / Lx210 fuel sender upgrade replacement
I spoke with Don a little bit ago. He told me that Yamaha used a couple of different units back then. The one with 3 wires is NOT an isspro unit. He said the third wire is for a low gas light. So The new one I bought will work, I just won't have the idiot light, which I don't think is that important. He also told me that the 5 holes are not evenly spaced so I need to make sure the new unit is put in right.
Fuel Senders for the LS / LX series boats. Mine was for the LS2000 (99')
I spoke to ISSPRO today, they MFG the original fuel sender for the LS2000 boat model. plug n all (12.5" long stem/sender) Spoke to Don in Technical support, he has the exact model for replacement with all the new technology to accommodate the ethanol and fuel additives. I found ISSPRO name and P/N on the sleeve for reference. Plug n play setup. $110.48 + freight. 1-888-447-7776
He informed me failure is due to the newer fuel additives and corrosion properties not present during the time frame of MFG. in 2000' All the new units are up to today's standards. Cheers to them.
If it's a ISSPRO unit, call Don First, they can duplicate all models in house if not in stock. Some members bought the generic version that's 1/2" shorter, that's fine but not reading the exact amount of gas left in tank can be a burden.
would this fit a 2004 lx210?
Just call ISSPRO they are fantastic with their product knowledge and customer service. If you have the info from the old sender or just pics of the top where the wires connect and the overall length you need they can make it for you or sell you something close from their stock. I had them send me the off the shelf model that's a little short...that's my reserve tank...I rarely let it get below 1/2 a tank anyway to keep condensation from forming.
Yeah, just call them. Most everything is customizable anyways. They will have something pretty close to whatever you need.
Spoke with Don today and he is sending a new unit for me also. Should be here Monday. Thx for the info guys.
Good info guys mine is not workin either
Refreshing this thread. Don is still alive and well with ISSPRO fixing people up. $170 to my door in Texas and I connected it just like he stated with the position of the foam seal as well. Works perfect and feel a lot better with an accurate fuel reading. Went from between a 1/2 and a 1/4 to between 3/4 and a full tank. Only about half a tank off :D
