internationalmarinemike
 - Boynton Beach, Florida
 - Other
 - Other
 - Other
Really nice job on the dash layout.  It looks amazing.
@waterboy I really liked your mounting method so I used it to mount my new Garmin and can't wait to try it out on the Bimini trip. Thanks to @internationalmarinemike for helping me choose the unit, so far I really like the Garmin 54dv unit.I thought I would add in my new install on my Chartplotter. See pics below. I used a 1.5 inch Ram Mount as shown. Instead of a permanent mount or otherwise, I used a Seasucker vacuum mount. It is rated to hold 40 lbs so this is not going anywhere. It also removes easily and cleanly when not needed.
I am very happy with the clean look of the install and it is very stable.
View attachment 18971 View attachment 18972
Correct, the stock transducer is not compatible with the Garmin. To minimize the size of the holes you drill, you can use a transom mounted transducer instead of a through the hull one. My new Garmin transom mounted transducer worked great.Hey guys, newbie to the site.
I have a 2014 242 and want to install my Garmin 720S.
I am stealing the SeaSucker/Ram mount option for the head unit (I really hate drilling holes in a boat).
Now, that said, I gather that the stock Transducer will NOT support my Garmin....Correct?
And If not, I guess Im Drilling and even larger hole in my boat?
How did you attach the Ram to the SeaSucker?@waterboy I really liked your mounting method so I used it to mount my new Garmin and can't wait to try it out on the Bimini trip. Thanks to @internationalmarinemike for helping me choose the unit, so far I really like the Garmin 54dv unit.
I attached ram mount to the seasucker using pan #8 stainless steel bolts with nylon lock nuts. You have to take the plunger assemble off the suction cup (4 pan head bolts) to attach the ram mount. To mount the Garmin bracket to the ram mount I used the same hardware, the only difference is I used 3 bolts instead of 2.How did you attach the Ram to the SeaSucker?
	Would you mind sharing where you got the ram mount with the suction cup, I have looked all over. I have a echomap 53dv. ThanksI love my ram mount sucker...only moves when you engage the quick release.
I will try that. Thankshttp://www.rammount.com/ They have an entire section on boating and fish finders. You can order direct from them.
