haknslash
- Lake Martin, AL
- Moomba
- Other
How diff is the dual axle trailer? I'm nervous about the bigger size lol.
I love it! Rides so much better than the single axle Shorelandr trailer did.
I found my single axle to be very touchy like you barely turn the wheel and Jack knife lol. Is the dual axle a bit less touchy when backing her down? Still a bit nervous going from a 19 to a 24.5
Sick. I also upgraded the jack since it will be sitting on the trailer in a driveway. Just confirmed with my dealer she is Def salt worthy. So I will be taking her in the sound. Prob not to wakesurf just for cruising around.Nah it’s great and not twitchy. For starters there’s a lot more weight which helps but also the length takes the twitchy feeling out. Backing it up I’m much more precise than the shorter 19’ trailer. The Boatmate trailer is well built and feels solid. You’ll be fine.
I'm so ignorant to this type of boat idk what a exhaust cat is. I just figured I'd ask you about what to use to flush and since my dealer owned a watersports school in Florida I'd ask him the best procedure to flush. I won't use the ballast since I don't want any salt water going through the pumps unless it was somehow necessary due to super chop or some shit. Since mine is all white im a bit lucky with the salt clean up. But I've gotten very anal and use to cleaning the entire boat after every use. And my dad is the sound guy. I'm a lake guy. And he doesn't get how much work it is to take a boat out with just my mom.Yes in the Indmar owners manual it tells you the engine and such is ok for salt water use. The engine is closed cooling. The exhaust cats and other areas are raw water cooled so those are the areas to deal with corrosion. I would highly recommend you getting the Indmar flush kit. I don’t think I’d have the balls to take mine to the gulf. The boat would be fine but it’s just too nice to deal with all the salt cleanup lol. Did you get a spray date yet and are you planning on going to do a factory tour? If you time it right you can see yours being built on the line like I did with my Max. It’s pretty cool seeing how they’re built.
