Need help - Lots of water draining from plug on '17 212X
MidnightRider
Zumbro Falls, MN
Malibu
Wake
Seems like that much water would be from more than a little silicone missing from one screw in a fitting... But worth a look, I suppose. I agree with @Gym that the drive shaft seals are suspect at this point. If I am reading correctly, it leaks when running but probably not as much when not.
Yamaha's seem to be very hit or miss on this point. We have had people who have had to hunt and seal multiple leaks and others (like me) for whom it is basically bone dry right from the factory.
On the rear tray thingy: I removed the silicone and replaced it with a thin weatherstripping. I remove it too often to always mess with the silicone. No regrets.
Not "one screw in a fitting". They basically missed the entire one side of the clean out tray with the silicone bead leaving a crack the length of the clean out tray. But agreed, I didn't have the "more than a gallon" scenario going on.
GoVols01
College Grove, TN
I did the rear tray as well with a rubber seal.
tdonoughue
The Woodlands, TX 77381
@MidnightRider , I was not referring to your post in the 'one screw' scenario, but rather @sunbyrned 's post re: the silicone on the screw on the drive shaft plate.
But we are agreed: this is a lot of water. It is coming from someplace substantial...
sunbyrned
Louisville, KY
Mine is a long shot for sure. If they didn’t silicone any of the screws though, you’re looking at six potential areas.
sunbyrned
Louisville, KY
One more thing... you don’t have to pull the pumps to check. You can feel them through the clean out ports.
buckbuck
Texas
I would suggest you revisit the anchor locker drain. I know you said the locker is dry but can you confirm that no water is entering the space between the inner and outer hull?
BoaterGuy
Does anyone have a link to cork that fits the drain?
Jameson Clark
Laurens, SC
I need to do some looking into the anchor locker drain myself. I don't really even understand why it is there really. Maybe I can put a drain plug in from inside the anchor locker?
MidnightRider
Zumbro Falls, MN
Malibu
Wake
Tms1224
New Hampshire/Mass
242 Limited E-Series
Video: Mystery leak in 2017 212X
Recorded this video Saturday after I pulled the boat out from 1/2 day on the water. This time, I was finally able to measure the amount of water that came out of the hull - 5+ gallons! This crap CAN'T be normal.
I’m original owner. I’ve had this boat to my dealer 2 times to fix this issue with no resolution yet. So far, they identified leaks around the exhaust through-hull gaskets and leaks along the swim platform rub rails. Both were “fixed” yet I continue getting a large amount of water from the drain plug after day trips to the lake.
I put a rubber seal around the access panel by the clean out ports already, but it made no difference. I’m thinking it’s leaking from the shaft seals because dealer will leave it in water overnight and says there’s hardly any water the next morning. I told them it seems to occur while boat is underway, - shaft seals - but dealer says it’s impossible. I don’t understand why though.
Any ideas what else this could be? Boat is under warranty still. It’s at the dealer for the 3rd time now for this issue. If they can’t fix it this time, can I lemon law this thing? If I witnessed this from a used boat I was considering buying, I’d run! This is my concern going forward, as well as having to repair it outside of warranty terms.
I saw in your response to somebody asking you about the anchor locker. You said you sealed it . Where did you seal it ? Did you seal it near daylight or close to the storage side of the locker ? The reason I ask is I plugged mine at the daylight side and it has seamed to help with my water issue . Looking down the hole you can see a seam where the hulls meet .
GoVols01
College Grove, TN
I pumped the whole tube full of caulking and made it flush with the outer edge on the water-side of the opening. This had no impact on the water in the hull, so it's not the problem. I found the problem with plugging the anchor locker drain is it became 1/2-filled with rain water when I got caught in a rain storm, so I pulled the caulking back out to let it drain. On the way home yesterday, I bought some of the Attwood bailer 1/2" ID bailer plugs to seal it off - they're kind of like wine bottle plugs, but smaller. The anchor locker drain is a piss poor design. Coming off plane, the bow sets down in the water and drain goes below the waterline, filling the anchor locker with water.
Tms1224
New Hampshire/Mass
Ya I have the same plugs .. didn’t think it would stay in but it does
Cambo
Long Island
Testing for water intrusion on the 242x a cork was installed in the rear clean out tray then I filled it with water and watched how much poured out. With all the screws and the rubber gasket on the removable tray it looks like it could be water tight but its not even close. As you slow down waves splash up and get under the hatch and water can back flow from the drain, I haven't seen or documented the drain but it looks like it could easily back flow into the tray area. I have some neoprene closed cell self stick foam That I will use on both the tray and removable hatch
103053
haknslash
Lake Martin, AL
Moomba
Water does not come over the swim deck. Notice sea deck is usually dry on upper deck. The water comes in the tray from the drain as there is no check valve. Water rushes under the swim deck, goes into the clean out tray drain fitting, flows up the drain hose and back into the tray. Think of it as the same issue as the anchor locker. @2kwik4u did a test on this a long time ago and stuck a GoPro in the clean out hatch to see where water truly comes from.
JDRacing
Northern Calfornia
Water does not come over the swim deck. Notice sea deck is usually dry on upper deck. The water comes in the tray from the drain as there is no check valve. Water rushes under the swim deck, goes into the clean out tray drain fitting and flows up the drain hose and back into the tray. Think of it as the same issue as the anchor locker. @2kwik4u did a test on this a long time ago and stuck a GoPro in the clean out hatch to see where water truly comes from.
That is really interesting. Has anyone tried installing a check valve in that drain hose instead of the seemingly more difficult effort of trying to remove and then seal up the tray? I will look at the drain hose area today to see if it is easily accessible.
If the check valve idea works, it should also prevent water from filling up the clean out tubes above the plugs.
tdonoughue
Nah. That would be easy and make sense... :banghead:
Now, why didn't I think of that...
haknslash
Lake Martin, AL
Moomba
Yup we were all trying to figure out how water gets in there. I tried everything I could to get water on the rear deck and never could, even when driving stupid to try my best lol. Here’s the thread we were discussing it and how he eventually figured out how the cleanout tray gets soaked and how water gets on top of the plugs https://jetboaters.net/threads/2018-ar195-filling-up-with-water.18602/. Page 2 has the details of the water intrusion. I had suggested a GoPro but he ended up removing the clean out hatch and taped down the safety switch.
JDRacing
Northern Calfornia
So, I removed the inspection cover on the clean out tray. The hose is right there. Looks like it is a 1/2" or 3/4" ID, reinforced hose, but I didn't pull it off to measure it. Either a check valve, or even a small seacock, could easily be put inline. If more water is coming up the drain than going down, then a seacock might make sense. Either way, it's a cheap experiment, and I will give it a try as time permits.
Jeff
Neutron
New Bern, NC
Jeff
My drain hose is made of that clear hose with the crosshatch pattern in it. It use to be so long that it was always kinked close. I did shorten it then noticed more water in bilge. So i put a temporary plug in the drain and once again there was very little water in the bilge.
I also pay close attention to how the clean out plugs are seated now. I used to always see a lot of water above them so now when i seat them in, i push hard again and wiggle them, pull on them and once i get zero movement i am satisfied. Now i get zero water above the plugs unless we are dripping water onto the second tier.
haknslash
Lake Martin, AL
Moomba
Another tale-tale sign is if you notice usually the clean out hatch underside will be wet. This is from the water shooting up and out of the drain like a spigot when you come off plane.
