Never Seize on spark plug threads
Looper7
Chillicothe, Ohio
I say yes and I do on my boat it just takes a tiny amount. Be sure not to over torque
yay, but change them often and you don't have to,
Cobra Jet Steering LLC
Do a search lots of opinions on that topic, I always do , but I never use a torque wrench when installing the new plugs ,tight and then add 1/4 to 1/3rd turn.
  • Like
Reactions: Gym
Cambo
Long Island
yes i like it copper anti seize
biglar155
Fredonia, WI
Yes.
Also, when I put that on my spring commissioning list, I added in big bold letters "Don't over tighten! Remember - Aluminum Heads!"
I need constant supervision - even if it's by "younger me."
Gym
Falmouth, MA (Cape Cod)
Can't hurt but can help. Just use common sense about torquing.
ZGhost
Minneapolis, MN
Yes, small amount, hand tight, then 1/4 turn to snug. Been doing this for years.
  • Like
Reactions: Gym
Dixie Highway
Daphne, AL
I’ll be a dissenter here. In aluminum heads never, if you are checking them occasionally you should never have trouble with them seizing.
BlkGS
Melbourne, FL
This is exactly what I do. I tried this year leaving them only partly threaded in over winter after fogging, enough to close up the hole, but not enough that there could by any issue removing them.
Spark plugs changed every 6 months?? not me I run hundreds of hours a year but I use iridium plugs so if they run fine I leave them alone. And I use never seize plus silicon grease on the coil boots But everyone has their own preferences.
