swatski
- North Caldwell, NJ
Missing sealant in the pump intake will potentially let air enter (from the bilge compartments) and that would cause "cavitation" (or ventilation to be exact) and for sure decrease the efficiency of the pump and result in decreased performance as far as thrust.Thanks everyone for your comments and feedback. The boat is perfectly clean and was just put in the water, so growth on the hull isn't a part of the issue. I think OrangeTJ is on to something regarding the sealant on the intake side of the pump or the clean out plug not being sealed.
I've noticed that the clean out plug fills all the way to the very brim overnight. I empty the water before use by simply removing the clean out plug and then putting it back in, but the next day it's filled to the absolute brim (so that the ski ropes that I store in the same compartment are wet, so it's probably overflowing). I make sure the plug is in tight. Could this be the speed robbing culprit?
Separately, any dings on the leading or trailing edge of the impeller or the stator segment may cause cavitation.
As mentioned before, the clearance with the wear ring is critical, I don;t know how good those are in the new pumps, but should be great with the plastic inserts/lining, unless damaged.
