Mdsmith000
- Limited S
If it fits as OEM $85 is not ridiculous for a small run plastic cover. Molds are not cheap. There was an attempt to 3d print covers that have sort of fizzled.
Heck I pay that much a weekend on fuel.
Fizzled no more. I will post some samples later today or over the weekend. $20 shipped.
$85 is a lot for a plastic cap IMHO. I wish I only spent $85 on fuel for a weekend on the water. $20 much more doable.If it fits as OEM $85 is not ridiculous for a small run plastic cover. Molds are not cheap. There was an attempt to 3d print covers that have sort of fizzled.
Please put me down for one, in Black if possible, otherwise whatever is available.Fizzled no more. I will post some samples later today or over the weekend. $20 shipped.
@Mdsmith000, is that 80mm diameter external or internal?
I am getting 77mm ID on the existing model which has been confirmed to fit.
That's all I got from the manufacturer which can be found here.
Nope it blew off,Do you happen to have a broken cover that you could take pictures of? Does the cover overlap the lower section?
Nope it blew off,
