nclacrosse
- 242X E-Series
So we have had this boat for just about 1 year. Since new, I would occasionally see a really small amount of oil in the bilge area. I asked the dealer to check it out at end of season last year and they said they did not find any cause / leak. Recently the amount of oil I am seeing has increased (especially if we have been running hard pulling a big tube etc) and I now notice it in the bilge water. I did a little exploring today and the only oily surface I could find was under the starboard engine. Is this most likely an oil pan that isn't snugged down tight? Pretty sure the oil pump and cooler were not leaking.
MYSTERY PART - Also there is a cylindrical "port?" of some sort under the starboard engine toward the outer side that is not on the port engine? I thought the engines would be identical? I wasn't able to see under there but I drew a diagram based on what I could feel. It is smaller in diameter than the oil filter and almost feels like a sleeve with a cap pressed into it. Kinda like a 2 piece filter wrench or plumbing clean out port? Can anyone tell me what this is and why it only appear on 1 engine?
