84rzv500r
- Lower Keys MM29
Boat progress today:
Got most all of the coolant lines cut to fit and dressed out need to clamp up.... will get some more pics tomorrow it was just to damn cold and windy today
was having difficulty getting engine mounts where I wanted them... so I took some 14mm OD x 8mm ID nylon bushings to center the mounts in the engine flanges... Now I can bolt the engine mounts to the engine rails in the boat and still have adjustment if needed... the couplers are within spec and the mounts are where they need to be... that was my last inexplicable mental hurdle... should be all bolted in and plumbed for cooling and exhaust tomorrow... if I get time I'll dress out the electrical harnesses... I need to order some Deuch connectors to eliminate the security system and connectors to expose the tach signals and marry the original ignition harnesses to the MR-1 harnesses (thanks Robb235 for sorting most of that out)
Got the Neoprene Foam to finish building the new seat cushions
Todo list:
Install AR230 Throttle cables
Install AR230 HO Tachs
Install Autometer mechanical Oil Pressure gauges
install ski locker fuel cell, check valves, shut off valves, pre/post pump filters, pressure regulators, and walboro pumps
order & Install LiFePO4 batteries
replace port engine Steering cable
wire up new speakers and AMP, replace kicker grilles on the other speakers to match...
install new cockpit Lights
sew up new Bench seat, and backrest cushions
Sew up new engine compartment deck and hatch cushions
and 10 other things I'm forgetting
So this stuff is much firmer than the open cell stuff...and it dont absorb water... I'll have to triple it up on the engine bay deck to match the height for Blond Beach Barbie
You do know I make this up as I go along... LOL
Todo list:
