84rzv500r
- Lower Keys MM29
Who's taking video of the maiden voyage? Drone footage?drum roll please...
ready to drop in boat tomorrow...![]()
I am missing the 4 funky bolts that hold the intake horns to the throttle body on the port engine... i found the only two in the US... the others on backorder... I'll use some OTS Stainless cap screws and washers for now... Im also missing one exhaust transition coupler however that should be here tomorrow....
Some fresh Dykem showed up today so the engines go in and the final positioning, layout and welding on the mounts can happen!!
I got the engineering/mfg drawings for the belly fuel tank... I need to check all the measurements and sign off release to build...
View attachment 169048View attachment 169049View attachment 169050View attachment 169051View attachment 169052
Lol there is a bit more work to do... we will get some video... I wont have the fuel cell for a couple weeks yet and there is just a bit of prep for that... and I have a ton of wiring integration details to deal with but the heavy lifting is all done... I have to find a place in the console for the mechanical oil pressure gauges, install and wire up the AR230 HO Tachs, install the throttle cables... Cooling water hoses in and out... the port steering cable needs to be replaced as it has locked up in the interim...Who's taking video of the maiden voyage? Drone footage?
Was it a lot harder getting the 2nd one in due to space?and in case you were wondering what a pair of MR-1 HO's would look like in a LS2000/AR210 here you go...
thats all for today...
View attachment 169467View attachment 169468View attachment 169469View attachment 169470
no I planned for it... i did have to pull the exhaust transition cone off but that was it.... the engines go in the hole crossways then rotate 90 to set on the mounts... I have lots of room once they are in place... there is room to slide the engines forward 4" to allow for service of the mid bearing seals and laterally 2" each way to allow the other engine to rotate for installation/removal. there is also plenty of room around the engines for access... and you can actualy stand between them and the oil tank makes a good seat... lolWas it a lot harder getting the 2nd one in due to space?
Looks awesome! Great job!!!
