Rotax engine substitute oil filter ?
Janguh Lang
SW Detroit
Scarab
HO Impulse
The Man! Is what you are. Thanks. I will have to dig out my literature and take some snapshots so I dont have fine folk doing MY homework.
Rearwheeln
Scarab
165 ID
They dont have to be changed if they look good, but it is recommended. Glad you like your upgraded filters!
Hi Mike , hey I just changed the oil and measured about 100-103oz that I pulled out . Could you tell me if this sounds about right. I used a older style filter and the one that I pulled out was a newer style wish I had paid more attention to what filter I ordered. Also switched oil to shell T6 since mine is the 150 hp motor. Sweet posts bud ! Thanks
Geeman
Scarab
255 ID
Scarabmike, you out there? I was curious if that oil filter part # is good for my 2019, twin 250 H.O.'s The dealer here in Austin really doesn't want to help, unless I buy from them. I'm doing most of my own maintainence, and doing the first oil change myself. Anyone know where I can buy a used Candoo, these guys are trying to bend me over on the resets?? Thanks to you, and everyone who donates their time, and their expertise here!!
Dean P
Chaparral
VRX
ScarabMike is not there. I use his recommended oil and filter. No issues. You will need an inverted socket to remove the oil filter cover. Do a search for specifics.
Geeman
Scarab
255 ID
Dean, Thanks for the heads up! I didn't see what oil he spec'd, but thought the stock filters looked cheap. I have tools for days (45+ years of car, boat, plane tinkering)
Dean P
Chaparral
VRX
This is what he recommends and what I use.
Geeman
Scarab
255 ID
Dean, I really appreciate your time!
Geeman
Scarab
255 ID
Dean, sorry for my ignorance, I see the Rotella is full synthetic. Are you guys running this with no problems? I saw in the manual not to run it because of the lack of cohesion with the superchargers. I prefer to run synthetic in everything.
Thanks
Dean P
Chaparral
VRX
Thanks
IMHO I don't think you have anything to worry about but if you're not comfortable you can always get this.
Geeman
Scarab
255 ID
Dean, I really appreciate your help, and patience. New boat, and these guys are sticklers here. Synthetic out performs conventional in every way, I just don't want to void my warranty. Your superchargers running this no problems though??
Dean P
Chaparral
VRX
You're fine. We're just trying to help. I too had the same concern. Read here.
I copied this from my owners manual. Different boat, same engines (unless you have the new 300 hp).
ScarabMike
Green Cove Springs, FL
@Geeman You will be fine with the rotella. As long as the oil is rated for wet clutches (JSO-MA) you will be fine. Rotella is better than XPS. You can also use Amsoil.
Geeman
Scarab
255 ID
I just want to say thanks to you guys for all the help. Very refreshing, unlike the guy on here trashing the Scarab brand.
