C'mon up north a bit! The Wolf is still a touch high and running fast!
@buckbuck Not 100% certain what I'm seeing there. Are you pumping mud at the beginning? Did you actually run aground? What kind f depth was that? I'm guessing like 16in?
Forgive my ignorance, I'm just curious.
I'm spoiled with very deep water where I boat. It's all small rivers that were dammed up to fill in the valleys with water. It's really uncommon for us to be in less than 20ft. I have to work at finding places where we can just step off the back of the boat and not be neck deep in water.
Never had the boat on Kentucky Lake or Barkley. Been to Cumberland, Dale Hollow, Rough RIver, Nolin, Green, Patoka (IN), Taylorsville, and Douglass (TN). Wife rented a pontoon one year during her annual girls only trip on KY Lake. She didn't venture far from the marina though.You are not far from the twin lakes, Kentucky Lake and Lake Barkley. The only deep part of those lakes is the main channel (original river). Bays and open water are relatively shallow. If you really want to make a trip come to Estero Bay in Fort Myers. During low tide there are not many places deeper than 2 feet.
I rarely jet boat in Estero bay because it is so shallow and have to stay in the channels. Drug bottom too many times. My fishing boat has a 4” draft so it is my go to bay boat.Never had the boat on Kentucky Lake or Barkley. Been to Cumberland, Dale Hollow, Rough RIver, Nolin, Green, Patoka (IN), Taylorsville, and Douglass (TN). Wife rented a pontoon one year during her annual girls only trip on KY Lake. She didn't venture far from the marina though.
I think I'd be a nervous wreck in 2ft of water constantly. So used to "hitting bottom" being something you just don' thave to worry about. Even 25-30ft off the shoreline it's usually in the 15-20ft range.
Fortunately the Scarab has a self contained cooling system. Jet drive in shallow water is definitely an advantage over prop drive. Two of the main reasons I chose the jet drive.Yea we don’t have real shallow lakes or rivers like that here. I mean we have shallow areas to avoid on a few lakes and rivers but they are outside of the channel. For surfing you’ll want a minimum of 15’ depth or the wave drastically turns to nothing.
No way I’d want that stuff going through the cooling system!! For sure would make me nervous with any of the newer boats with the AK rudder. Snap that thing off hard enough on bottom you might bust the drain plug too.
Okay, @buckbuck, I raise you (granted, not surfing at the time).Heather's surf run was interrupted when the boat suddenly slowed. Fox River is a bit low right now. Glad I own a jetboat.
This is my only way out during low water times, I would say a good 6" is a minimum though, lol. It's all silt but still takes a bit of... dedication.
The video clip is a bit off, it gets pretty tight behind that bend (and I had to focus somewhat on driving, lol). No alcohol is involved, just pure dedication to be out on the water. My FLorida friends think I'm nuts, but hey, its Midwest and we do what we can.
Well, us midwestern boaters have different challenges... The biggest one: no ocean here! lolOuch. That sand and grit has to abrasive to the impeller and liner.
Saying that. Been there powering through a sand bar so shallow the boat is tilted on one side of the V bottom. I just grit my teeth and power through to deeper water. Jet drive not failed me yet. Do that with a prop.
Roug
Wonder if you came through with a bit more throttle if you could "reshape" that channel a little with the jet wash. Looked like you were still getting clear-sh water to the jets, and the mud was getting stirred in between the two sprays.
I seriously can't imagine boating in that shallow of water. You guys are nuts.
The exhaust manifold does use raw water for cooling. That is why it is important to flush the exhaust afterwards especially in salt water. The self contained engine cooling uses anti-freeze so I don’t get sand into the engine head cooling chambers. Anyway you look at it sucking in mud or sand is not good. I’m getting better about staying off the bottom.I’m not too familiar with BRP engines but I thought it still used raw water for other parts in addition to closed cooling. I could certainly be wrong though as I’m just not that familiar with BRP engines. My Raptor engine is also “closed cooled” but it also has raw water cooling in other places.
