Hunter
- Oakville, ON
- Scarab
- HO Impulse
Hi I took my scarab 215 HO for a run and on the way back from the beach the Engines weren’t in sink then a squealing Sound from the starboard engine when I turnd of the Engines and tried to start the starboard engine it would make one click attempting to crank then wouldn’t crank. When I checked the engine temp the starboard engine was 201F while the port engine was 192F. Also there was no warning lights like high temp.
Had to limp back on the port engine to the dock. I let the engine cool then tried to crank a second time then the same results.
When I got home I put a scope in the outlet hole to see if something was jammed in the impeller.
I also checked all the fuses.
Anybody experienced this or know what it is.
