DCB-270
- Edmond Oklahoma
- SS
I got mine from Amazon. About $65.
Are you saying that you need to grind the diameter of the hole in the boat?Bruce,
I believe the 230 needs a bit of a grind to get the stainless scupper in. Not a big deal but not as easy as the 21os.
Good to know, thanks!I couldn't see cracks on the outside of mine. It broke right where the threads start. Might need to lift the flap and check it on the inside.
Good point Mel.Just remember, both the scupper and the transom drain are out of the water when on step at speed! If you know for sure it is one of them, crank and go! But don't just assume, could be an exhaust or cooling leak and running would pour more water into the boat, not drain it.
