- Rosebud, Mo
- 242X E-Series
Good points Gym!
Ahh..I see. Thanks!That is the scupper valve. See how it's plastic; they are describing swapping it out for a better metal one...
The older boats had the scupper valve below the water level. I believe your boat has an above water scupper valve.Alright, so I remember seeing a lot of talk about the scupper. In looking at the boats everyone on this thread has they are almost all the older style boats like the 230. Is this something I should do on a 2012 AR240? I would go look at mine right now but I can't easily get to the back of the boat.![]()
You can remove 5200 but with a lot of difficulty and possibly damage to the bonded surfaces. 3M states "Recommended Usage: Permanent bonding, above and below water. Extremely strong & flexible." Whereas 4200 3M states "approximately half the strength of 3M's 5200, which allows for eventual dissasembly of parts." So if you ever want to replace a scupper or other fitting you may want to consider the 4200 or Life caulk.3M 5200 is not permanent. Only in a few applications is it permanent like bonding plywood to plywood and other structural bonds. I use 5200 a lot on below and above the waterline applications. It remains slightly flexible but water tight.
Man, that is one sexy drain!It has arrived!!
There's got to be a fellow member near you in that great big state of yours that could lend a hand!!!Do you have the tools and the skills to make that bad boy fit right? I'm afraid to touch mine since I don't have the tools and I'm not sure about the skills yet.
Pearce, Non of us had the skills before we tackled this job. It's just a matter of taking things one step at a time. It's really not rocket science. The most difficult and time consuming part of the whole job is removing the clean out tray to access the lower bilge and removing the starboard water box (muffler). It's not technical just time consuming.Do you have the tools and the skills to make that bad boy fit right? I'm afraid to touch mine since I don't have the tools and I'm not sure about the skills yet.
Nice job and peace of mind knowing it's good.
