Gym
- Falmouth, MA (Cape Cod)
- SX
Good catch @ToddW850. You just avoided a potential, on water breakdown. Now, take a real close look at the black plastic nuts holding your kill switches down. You only need to open the clean out hatch to see them. Both of mine were cracked causing the switches to be fairly loose and allowing them to be pushed down out of adjustment if the hatch door was closed or slammed hard. Mine didn't cause an engine shut down but would have had I not found and fixed it.
The broken clamp you found may also make you want to think about installing tow valves or at least carrying a couple pairs of clamps or pliers in the event you need to run, at greater than no wake speed, on one engine or need to be towed. Just food for thought.
