jdonalds
- Redding, CA
- SX
Isn't it also true that the scupper in the newer boats are above the waterline?
That is correct @jdonaldsIsn't it also true that the scupper in the newer boats are above the waterline?
This whole thread had me in 'action' mode, to be safer than sorrier and change out my scupper. I write this because I have an '08 212X, not the 230 like most here, but wanted to give my experience....so far. I ordered the part from attwood like others here; I was advised the part is universal.In addition, The newer boats, can be checked and examined through the inspection port in you Plug clean out tray. Easy to see and feel.
That is exactly what happened to mine. As soon as I touched the threads it broke.This whole thread had me in 'action' mode, to be safer than sorrier and change out my scupper. I write this because I have an '08 212X, not the 230 like most here, but wanted to give my experience....so far. I ordered the part from attwood like others here; I was advised the part is universal.
As Boat Crazy eluded to, I can just pop off my inspection port cover from plug clean out tray and look down in there to visually check it? Well, I just did this, and you can't see a darn thing due to starboard muffler in the way. So I removed the clean out tray, and now I have a full view down of scupper and white drain hose. I loosen the hose clamp and reach down to check the plastic nut and WALLA!, the scupper thread breaks off right in my hand with no force whatsoever!
I'm not trying to start a full blown panic attack in ALL Yamaha boat owners, but I kinda thought I might be overzealous by changing mine out, but am very glad I checked mine today. Cause afterall, it won't happen to me, right? Lol
@Bruce,@PEARCE, I ordered this stainless steel scupper for $55 . It looks like it will fit but I have not gotten around to installing it yet. #Scupper #Maintenance
http://greatlakesskipper.com/standard-stainless-steel-1-1-2-inch-boat-thru-hull-valve-w-scupper
Then DON'T replace the plastic scupperI need another reason to buy a newer boat...I'll upgrade the scupper instead.
That looks exactly the same as the Attwood scupper I used. They are probably made by the same manufacturer.
