Sotally Tober
- San Diego, California
- 242 Limited S E-Series
I really can't see any pros. I back into sandbars and all the time and have never had an issue with the keel. The TVs hang stupid low so I can see that being an issue, but I stick with CJs and don't have that issue lol.
"I back into sandbars and all the time and have never had an issue with the keel."
- I have personally witnessed damage to the Articulating Keel from backing into a sand bar. My buddies AK was damaged when the wakes of boats passing my caused the 242 to violently bob up and down and in turn slammed the stern at angle to cause the damage.
"The TVs hang stupid low so I can see that being an issue,"
- It is an issue. That's why I install the hooking points keep them raised while backed in the Sand Bar (see pic below). Another option is to manually raise them then shove a noodle into the jet nozzles. I have personally had to replace a Thrust Vector on my old 2013 212SS due to damage it took from backing in, again from wakes of passing by boats causing the stern to slam down. I suspect this is the reason that Jet Boat Pilot designed the "Kick Stand" into their redesigned model.
"but I stick with CJs and don't have that issue lol
- Be careful.... like the Thrust Vector Damage, I have also had a bent Cobra Fin on my 2007 AR210, once again caused by wakes of passing by boats.
"I really can't see any pros."
- I cant really see any cons to the removal in my own situation. The first four Yamaha's I've owned did not have an articulating keel and was able to pilot them like a champ. So for me personally, removing the AK was a no brainer.
