212s
- 1000 Islands
- 212S
That sounds like a good deal...WS sells them for about $500 a pair?Here’s a good deal on Wet Sounds Revo 6s for $350 a pair
Wet Sounds REVO 6 XS-S 6.5-inch Marine Coaxial Speakers - Silver XS
Make a statement with one of the best performing marine coaxial speakers on the market, the REVO Series features a high power design to deliver incredible sound! Not only that, like with all REVO series speakers, you can go even further with the included RGB backlighting. Sold as a pair.www.atlanticrt.com
Actually NVX is just like Rockville (probably same chinese factory) with over-rated output claims, so you can expect about half the output from them. They'll work just fine, but don't expect to actually get the numbers they're suggesting.as far as amps you cant beat NVX amps from sonic electronics for the price.
CCA has more resistance, so copper is better for signal transfer. But OFC wire is a marketing gimmick to sell at higher prices...it does nothing to increase performance or power transfer - regular copper and OFC perform the same. OFC was created for those with clear jackets so you could see your copper wire was still "shiny", but outside the jacket at the connectors OFC will still tarnish just like regular copper even if you can't see it. It doesn't affect performance at all though, but it doesn't look "pretty". As far as electron flow is conerned, it's all the same - there's no magic here. The only reason stranded copper wire was chosen for speakers is that it's more flexible over solid copper wires. If I was wiring up a speaker system inside house walls, I'd use regular 12/2 electrical wire to the boxes - works great, easy to pull, meets in-wall code, and is typically cheaper than basic copper "speaker wire". Outside the wall, I'd run basic copper speaker wire to the actual speaker locations.Make sure to get OFC wiring for your system and not some cheap CCA from Amazon.
If you have an issue with corrosion in a saltwater environment, you might want to buy tinned copper speaker wire. Beyond that, just buy regular copper speaker wire at Home Depot or wherever it's sold at a reasonable price.
