Bowmax
- FSH Sport
Hey guys I am having an issue with my steering in my 2021 Yamaha 210 FSH Sport. I took it out for the first time two days ago and noticed that there was a steering issue. I noticed right at the dock that when I turned left, I was only getting about 1/2 to 3/4 the turning "radius" that I should have. I could turn right no problem. When I got home and out of the water, I noticed that the jets would turn fully to the right but when they turn left like I said previously, I am only getting about 1/2 to 3/4 the movement that I should be.
To try and figure the issue out, I disconnected the connecting arm from the rudder to the right jet outlet and the issue was still there. I thought maybe the rudder was sticking so I have removed that from the equation of being an issue. I then disconnected each steering cable from its Jet outlet, turned the steering wheel both directions and the issue was still there. I am thinking that it is my steering rack under the center console or the steering cable(s) have already seized up from ONE season on the water. When I turn the steering wheel left it goes around 3/4 of the way, hits a hard stop and then will go slightly more with a little more pressure and then stops turning completely.
I plan on taking it to the dealer this weekend but wanted to see if anyone else has had similar issues.
Have a good spring & summer on the water.
