- Florida
- Other
- Other
Thanks for your input I appreciate it and it gives me a chance to clarify some misinformation.
All the magnum A K steering systems are compatible with both the mega fangs and the side thrust adaptor called lateral thrusters.
The cobra steering for the 19 foot boats includes the Ultimate steering and the viper.
If the 19 foot boat does not have a keel then you can also add the MEGA FANG system for excellent reverse control better stopping power steering and even more all time steering however if the 19 foot boat has the rudder I will be offering a compatible side force stabilizer so that any of the late model nozzles can operate with my ultimate steering and the lateral thruster if you so desire.
I am doing this because my mega fang system is not compatible with the 19 foot rudder however the viper with the fangs built in is compatible so we want to give you the most options as always.
As for the E series I now instruct people to reverse the fin button cap bolt to avoid the reverse bucket being snagged if you do strike an object .
This picture was just posted by @Mainah ironically it shows the bolt I was just mentioning and you can see it clears fine but if you did strike a log or rock etc. with this system the bracket is designed to bend to avoid damage to the nozzle and it this happens the end of the bolt can contact the ribs on the reverse bucket and with the E series it will not have the force needed to move the bucket so it will put that engine in limp mode until you move the fin back to it's proper position releasing the bucket , this is why I suggest reversing the bolt on the E series models.
I suspect you did not have the MEGA fang setup on your E series 24 foot boat as this also greatly enhances the entire range of steering from idle to wide open without having huge fins hanging down under the boat .
