Irvs
- SX192
Ohh God, where do I start...
Last night I installed a kn 3.5 inch filter and removed the obstructive flame arrestor but left the rubber gasket in. Today I took the boat out with what started out as a normal boat run. Had 6 people on the boat with gear and a full tank of 87 octane ethanol gas.
Set the throttle at 6500 rpm and cruised for about .5 miles when all of a sudden I noticed like if I had reduced the throttle. At that point I thought nothing of it and gave it some more throttle to compensate back to 6500 rpm. Cruised another .75 miles or so when I noticed a second drop in engine power. At that point I slowed down and put the throttle in neutral. The engine died and I was not able to start it again. It would turn but not start. Checked for obstructions on the jet pump and it was all clear. Tried starting it until the battery was almost dead. Called a sea tow and got towed back.
When I got home I tried starting it again and the engine would turn and act as if it would start. Water came out of the jet pump.
Kept trying to start it to the point that I thought the battery didn't have enough juice.
Went to Sams and bought a new battery. Installed it and tried starting again until it acted as if the battery was dead.
Took the jet pump apart and everything was clear. The impeller was rotating freely.
Put it back together and tried again. Engine wouldn't turn. So I've been charging the battery since.
Hopefully the engine didn't seize or something.
I'm really worried because its a brand new boat. Could I have sucked in the rubber gasket?
I will remove the intake manifold tomorrow and see of the gasket is still there.
If the gasket is still there, what can it be?
I need suggestions....I'm already thinking I need an engine rebuild.
I did not get an overheating light or anything.
