tdonoughue
- The Woodlands, TX 77381
Perhaps it is part of the design making them quieter...
2nd thread with a 2015 with low rpm....hummmmm
http://www.jetboaters.net/threads/2015-limited-s-with-low-rpm-issue.6387/
Certainly were, our previous boat was a '13 carb model AR 240. I saw 48 mph once in it with 1/4 tank and three people at top end. Bad thing is so far I'm not even seeing 48 on our current boat.Were there CARB boats in 2013?
It's a 2013.
No, have not checks that, is that an easy thing to find on the engine? Any pointers on where to look would be appreciated.Have you checked to ensure that advancing the throttle levers all the way forward results in the throttle linkage in the engine compartment is going all the way to the stop for each engine? Easy to adjust if not.
