Top Speed RPM Question
Huskerjetboat
Omaha, NE
I have a 2013 SX240 HO and am operating at 2162 elevation. My top RPM is 7,000 and top speed is 46MPH. Is this what this boat should do? I was hoping to be able to hit 50 from what I have read. this is on smooth water with the driver and one passenger and a half a tank of gas. any feedback will be appreciated.
Scarabski
How is going to get that boat out of the water?
christopherglenn
I can see how elevation affects power, and rpm. I cannot see how elevation effects rpm VS speed. The impeller turning at 7k rpm pumps X amount of water, through the nozzle, generating Y thrust. Same weight same thrust same speed - no?
OrangeTJ
El Dorado Hills, CA
Correct re rpm vs speed. That said, perhaps 46 is the speed that relates to 7k rpm on your boat.
Huskerjetboat
Omaha, NE
Elevation is 2162. Middle Nebraska.
Huskerjetboat
Omaha, NE
tdonoughue
The Woodlands, TX 77381
Not the same year, but if recollection serves correctly, I get closer to 8k...
Hopefully I will be able to get out today and check.
McMark
Monongahela, PA
7k for me is about 45-46mph. 2015 ar240.
Huskerjetboat
Omaha, NE
McMark
Monongahela, PA
No. My top end is 7600ish and 51ish. I thought we were comparing at 7k.
tdonoughue
Agree. Out here now and tops at 7600 or so.
Huskerjetboat
Omaha, NE
Called my dealer and they are going to do some research. I feel I definately should be getting more than 7,000 rpm.
msavold
Columbia, MD
I get 7550/7600 and 51/52 with four on board at sea level in our 2012 sx240...
Ronnie
SF Bay Area
7600 to 7700 at sea level topping out at 51 to 52 mph.
