Jack Long
- Clarksville, TN
- Limited S
12x12 on mine
No mods
No mods
you could go old fashion and put a dedicated switch just for that and the secondary bilge pump !!!!!!
The secondary bilge has an float switch hooked directly to the battery so no real need for an on off switch for that.
I followed the diagrams, but can look it up if you like. Mine are on switched power - as they automatically retract when the system is turned off. Which is great as you will never forget to pull them up/retract that way.When you installed yours did you hook the wire to the auto retract to the ignition or did you just find a hot wire that was only hot when the boat was on? I thought about just hooking that wire to the remote switch on the radio since it turns off when I kill the ignition.
@swatski You said you would have liked to have the port actuator cable be a few feet longer, after talking to Russ at Lectrotab, they have a 28 foot one, would that be way too long? I'm not sure if I can cut the length down or not?
IDK, @swatski said in post #67 "The 23' of cable provided with actuator was just barely enough for the port side actuator assembly as it runs across the swim platform and then up the gunnel, would probably ask them for few more feet on that side just to be safe."That's true. The length that it comes with is long enough to go under the helm with no problem on the 24' boats. You need more than that?
I suppose it would how you run the cable.IDK, @swatski said in post #67 "The 23' of cable provided with actuator was just barely enough for the port side actuator assembly as it runs across the swim platform and then up the gunnel, would probably ask them for few more feet on that side just to be safe."
Yep, what I had was close (for the port side) but enough. I might have routed it further out along the periphery of the hull, who knows. The cable can be shortened, it is not like those for transducers etc, like @Bruce said. It has the conduit, but that just stays open - for pressure equalization inside the actuators.IDK, @swatski said in post #67 "The 23' of cable provided with actuator was just barely enough for the port side actuator assembly as it runs across the swim platform and then up the gunnel, would probably ask them for few more feet on that side just to be safe."
yeah I just talked to Russ again and he said its no problem to cut to length. they can do a 28' one for the same price. I'm going to get the "Swatski model" hahaha ordered soon. I'll also be picking it up from them since its only about 40 minutes away and doing a tour of their shop.Yep, what I had was close (for the port side) but enough. I might have routed it further out along the periphery of the hull, who knows. The cable can be shortened, it is not like those for transducers etc, like @Bruce said. It has the conduit, but that just stays open - for pressure equalization inside the actuators.
Ooo nice. Take lots of photosyeah I just talked to Russ again and he said its no problem to cut to length. they can do a 28' one for the same price. I'm going to get the "Swatski model" hahaha ordered soon. I'll also be picking it up from them since its only about 40 minutes away and doing a tour of their shop.
Yeah, I may need to upgrade to the AUTO controller, you guys keep saying great things about it.Just ordered the "Swatski model" from Russ at Lectrotab and he was very helpful. Also thanks @swatski for replying to my DM. Only change was I went with the ALC (auto level controller). Will update once I receive them.
I wouldn't know what to do without the ALC! Set and forget it. Yesterday was actually the first day I turned it off for a few minutes. I wanted to get her at WOT for awhile without the tabs dragging my speed down. In Windy conditions I hit 46mph @ roughly 7520 RPMs. I so wish I can hit that 50 mark. lolYeah, I may need to upgrade to the AUTO controller, you guys keep saying great things about it.
Turn up the stereo, it should give you a sonic boom!!!I wouldn't know what to do without the ALC! Set and forget it. Yesterday was actually the first day I turned it off for a few minutes. I wanted to get her at WOT for awhile without the tabs dragging my speed down. In Windy conditions I hit 46mph @ roughly 7520 RPMs. I so wish I can hit that 50 mark. lol
