2nazt
- Port St. Lucie, FL
- Tidewater
- Other
I would just believe that eash side button moves the indicated tab separately so you could push the left side to raise lower right tab and same for right side to operate left tab. (Not to be rude if you know the normal tab operations are actually opposit of the button you push. Some people do not know that. But the wiring and programming indicates you can change that if needed)
I know what assuming does but the up and down would just move tabs together . If it syncs them up I do not know or if it would operate them at a different height but move them together, you may have to call and ask those details. @Bruce may know how the up and down work, he has the auto but his also has manual up and down. I'm sure he will chime in on how it operates.
I only have independent controls on my boat.
