- North Caldwell, NJ
Got the R&D Skat prop today! Hope I can manage to put it on and run this weekend. The Vtech reflash along with this R&D 12/19 Skat impeller should be the winning combination!
http://www.4-tecperformance.com/index.php?main_page=product_info&products_id=1830
This is the impeller that seems to work best for moded VXR/VXS skis that have the same 1.8l NA engine and share the OEM impeller with all 1.8l boats.
Apparently, after a ton of research and testing, R&D couldn't get the Solas props to work well with the VXR like they do with other skis. They basically concluded the Skat was the way to go on this platform.
This is a new generation of Skats that require a special install/removal tool...
Interestingly, I was told by Jerry Gaddis not to use the billet cone/nose boot included... apparently a well know trick...
