More testing today, gorgeous day, but daylight is getting so short...
Here are some numbers I would like to share. Please keep in mind, this is just for fun, these "measurements" have so many caveats, it is not even funny...
After I got to my lake, about 2 mile run down the river, I have done 8 short runs each in Stock ("Backup" file) and Stage 2 ("103" file in my Maptuner) mode. Roughly 1/8 of a mile or so, whatever it takes to go from 0 to 40mph and then some, reverse, wait for the wake to subside, get in a position, and run in the opposite direction. Would like to do more, but it got dark fast...
I tried to get times from 0 to 20, 30 and 40mph, but my 20s were all over the place, so I gave up.
Here is the lake, you can see the water was beautiful, almost glass.
Maptuner connected to ECU and powered from the battery with jumping cables... It takes about 15-20 min to perform one reflash.
Running a 3/4 full tank of 93 octane, just me on the boat, have about 250lbs of sound deadening, heavy tower, full size bimini, full ski locker, 9ft keel shield, etc.
Here are the numbers (average+/- st dev, n=8 each):
____________ 0-30mph (sec) __ 0-40mph (sec)
Stock ECU_____ 9.3 +/-1.0______ 13.1 +/-0.9
Stage 2 ECU____ 7.7 +/-1.3______ 11.5 +/-0.5
(p-values are 0.01 and 0.002)
Boy, now that I look at it, these numbers are all over the place... Oh, well. I basically gunned the boat from a standing start. I get a lot of cavitation at low end, especially with Stage 2, which probably skews the numbers towards less of a difference. But, it is what it is...
BTW - I remembered to look up Boattest.com data - it is a bit different. They are citing 0-30mph at 6.8sec for AR190 and 5.1sec for 192... I have no idea how they get that... they must have less cavitation?
Whatever, I view these data as just indicating that the reflash gives a pretty substantial gain in power/acceleration.
For top speed, one seems to get somewhere around 3-4mph gain with reflash, but really impossible to compare fairly as the Stock ECU limits the revs at 7,800, and I do hit it with my boat in the config as above, albeit I do not think it would go much further.
The real question is, will the Stage 2 ECU reflash let me pull more ballast? Hope to get to it soon...
