What a beautiful day it was here today (albeit a tad windy)! So - I had to go ahead and do some more testing!
BTW - my wife is out of town..., so I neglected the kids, the dogs, whatever... Taking care of what is really important here. That little hobby of ours... What can I say.
It all started with a lot of troubleshooting this morning, the maptuner and the software uploads are about as friendly as a cornered rat... Took some time, several trips back and forth to the dock, and a bunch of frustration, but it all kind of worked out at the end... Must say these Vtech guys are VERY helpful, and assisted me on the phone throughout the day. I guess more on the product support somewhere else. Lets just say, it is not a perfect system, yet.
I tested several new programs including "Stage" 1 and 2 mapping, and back to stock, several times. Here is the bottom line - the best speed: (48.3 mph - see the bottom right corner of the speedometer app)
This was in "Stage 2" at about 8150-8200RPM, although I got not much less in Stage 1. This is a N/A single engine with no mods other than ribbon delete, and the boat is loaded with ~250 lbs of sound deadening, full tank of gas, a hefty tower, a large rigid bimini, a bunch of wakeboard/stuff in the ski locker, etc. Definitely not lightened for speed...
I promise I will post some tabulated results with impellers, RPMs, speeds, times etc, at some point but am limited on the testing/water time.
There is a couple of (random) observations I would like to share:
1. The thing is pretty addicting. I don't see myself running this boat back in a stock mode anytime soon...
2. With Stage 2 mapping - the kick in the pants acceleration is simply awesome. Basically, the boat travels from 30 to 40mph faster than it does 20 to 30mph in stock mode... if you know what I mean. Again, I apologize for not giving any numbers at this point, I will. But it is not subtle.
3. Predictably, the power is more palpable as you go up the stages. The boat coming to life would be an understatement here.
4. Missing now, but critical testing will be done with bigger loads. Ballast, lots of it, mimicking various scenarios, particularly for towing/surfing. I'm currently drawing plans for that.
There are several questions regarding top speed I would like to ask the board, maybe I will put them down in the next post, for simplicity's sake.
Somewhat obvious, but will mention it here anyway, per communication with Vtech techs:
"in the stage 2 and 3 files it is important to use premium fuel, recommend 93/94 octane for both performance and safety; as it is a NA engine much of the power comes from the added timing and it needs good fuel to perform as intended. Same with stage 1 tune to get best results you should put premium octane as you can, but it is not as sensitive as the higher stages are."
