McMark
- Monongahela, PA
I heard of others having problem with their seats braking on the same trip as well. So, I guess this is a thing too.
@McMark I looked at my mounts/inserts again, I used a probe to measure the void/space behind the insert - there is at least 4/8-5/8" of space in there. So, wouldn't it be better to have those bolts longer? Could easily be 1/2" longer, making any potential pull out so much less likely, not matter what.I just got out of my boat. Officially I get 5 full turns with no galling or cross-threading. 5 full turns doesn't put the end of the bolt all the way through the insert. The insert has about 7 threads.
Here are mine with those voids behind the inserts:
View attachment 62153View attachment 62154
That's what I was thinking happened when I posted earlier in this thread. A ton of force on just a few threads because a bolt is bottoming out early due to being too short would definitely cause cross threading on its own as it stretched the insert threads. Need to see what the bolt specs are against what owners actually have. I bet there are discrepancies.....and if so an obvious/dangerous quality control issue.Yes - you can only go that far. Look at the last video clip and the pics - the bolt only travels 2/8-3/8" inside the spring (inside the tower leg).
The Yamaha technical rep examined those bolts and threads and opined that one mount (strbd) was cross threaded. Nothing was said about the thread or bolt being too short. So, IDK.
I think there may be more than one problem going on here ( possible cross threading), but to me there obviously was not enough thread engagement to be safe. Those inserts were obviously threaded in to far, in my opinion.But if you look in @swatski videos with only the bolt in hand and no tower in the way he only got 2.5 turns till it bound up.
You have to start there. The threads are either already messed up or wrong pitch insert
Wow.View attachment 62183
For something critical that doesn't pass through the backside I would want at least twice the diameter in bolt engagement. I.e. 10mm diameter would require 20mm of engagement. -McMark
Hope you can read the picture. Jetboaters is blocked at work. It's general good bolting practices but slightly conflicting of each other.
