drewkaree
- West Allis & Fremont, WI
I was thinking of just putting a garden hose down the scupper drain on the floor deck and letting water flow down drain tube, open clean out hatch and look down at scupper valve above boat drain and see if water is leaking out of body of actual in scupper body. Good idea or No?
Several threads around here showing the nut on the backside of the scupper itself, which is right next to your pumps. You likely still have the plastic scupper. Fiddle with it through the clean-out hatch, tighten the nut, move it, basically check it to see if any "hairline" cracks open up to larger gaps when stressed in a different way than usual, such as when in reverse.
Running water through it is a pretty stress-free check, and likely not enough to show much.
