Where should I buy bearings for my 2007 MFI trailer?
Bonus points for part numbers.
This is the galvanized trailer for a SX230.
I would like to buy from an auto parts store instead of ordering.
Thanks for any advice.
The answer was Carryon 502T. Found two in stock at Autozone. Fit perfectly.
zipper
Boston Whaler
Googled it. A couple of screen shots.
dgfreeze
Central Ohio
If your wheel hubs are OEM, you will use the L68110 inner race. The industry standard is the L68111, so if you ever replace the hub (or if someone already has), chances are you'll be using two different inner races, like me. Three of my hubs use the L68110, and one uses the L68111. The kit you listed should have everything you need. Pay attention when tightening the spindle nut. Tighten it up pretty good, and spin the wheel to ensure things are seated correctly. Then loosen it until the nut spins free, and tighten again just past finger tight. Pre-grease everything. Good luck!
Turned out that my bearings were good but the weld holding the spindle to the axle had broken. I had the spindle welded and reassembled with the new bearings.
Volffas
Alexandria, KY
Does anyone know if the painted trailer uses the same bearings as the galvanized? I have a 2007 painted trailer and had a bearing go out tonight. Supposed to leave first thing tomorrow morning for a trip to the lake :(
dgfreeze
Central Ohio
I would certainly expect they do, but can’t speak from experience. 3.5k axle parts are fairly universal, not a lot of deviation. I’d be more concerned about the bearing races.
Volffas
Alexandria, KY
Thank you
