I agree with what everyone is saying. And that is a great price
@jcyamaharider for Impros, I paid $325 plus shipping for Concords last year.
Anyhow, the hard part is fine tuning the prop... Part of the problem is, in most cases we change the impellers when damaged. Which makes it rather difficult to get a good feel for any differences between models - the new impeller will always feel a whole lot better than the one you just used to find some rocks with.
So, until you start swapping and repitching undamaged impellers in your boat, nothing else is truly informative.
Here is what
@Speedling is running, and he knows his stuff. If I was running a 230, that is what I would do!
In my experience with 1.8l - I am honestly thinking the OEM prop with its longer blades is the best performer... I'm certain of it for a single engine boat, twins are little less prone to hole shot cavitation, so I am less certain. And with less blade surface, Solas should be the fastest. If you look at the side-by-side comparison with the OEM (or even Skat Swirl), Solas has much shorter, far less ovelapping blades.
Here is Skat Swirl, Solas Concord, OEM:
Regarding the Lucky 13 cone, I can not say enough good things about it. But, it is not a “one-size-fit-all” panacea for holeshot cavitation issues. For example, when I ran the L13 pump cone with a Solas Concord 13/19 prop, which gives me the worst hole shot cavitation, the cone did not help much for whatever reason. With OEM impeller, it was a different story all together. The Skat Swirl impeller falls somewhere in between. At any rate, you will have to tweak it to get best results - swapping spacers, boring the venturi nozzle and tweaking impeller pitch. Unless someone could tell me exactly what to do, I would not want to subject myself to it with a twin - I would just drive myself too crazy. You end up doing this (on top of swapping props or adjusting pitch):
Hmm, what spacers to choose...
Hmm, how much to bore the venturi...
