  • Announcing the 2020 Jetboat Pilot SEADEK Group Buy for JetBoaters.net members only! This is your best time to buy Seadek from JetboatPilot - you won't get a better price - the discount has now reached the maximum 30% already!
    So if you are tired of stepping on really hot snaps/carpet, or tired of that musty carpet smell - Seadeck is the best alternative out there! Get in on this now, or pay more later!
    You only have until Wednesday September 30th to get in on this.....So Hurry!
wont crank
robert cabrerea
Jacksonville Fl.
After a nice day on the ICW from Jacksonville to St Aug and back my exciter 135 single Will not crank and I double checked the rear clean out hatch. Sensor. It could be the starter relay I have a new one on order .starter itself had a loose positive cable and water damaged the cable that I have replaced. Im disappointed. But I should hopefully be able to figure out.
Speedling
Cedar Lake, IN
SS
Since you are thinking relay i assume it isn't cranking at all? Neutral switch on shift lever?
Fuses are also an easy check.
robert cabrerea
Jacksonville Fl.
Check and check.. It would click at the solinoid but just will not crank. Thanks for the reply brother
Cobra Jet Steering LLC
Vendor
Florida
probably a bad ground wire as well as the positive, the grounds go bad faster
robert cabrerea
Jacksonville Fl.
Thats a good point Cobra I will be working on it this weekend. Time to get out the multimeter. I will keep you all up to date. Im hopefull. Thanks for the replies
