Squirrel
- las vegas
- AR192
Just bought a 2013 Yamaha AR192 2013 and wanted to know some good things to do first to the motor/supercharger and boat. I got it from the dealer with 62 hrs on it. It has had the 50hr checkup. I am looking to do something simple first bolt on wise. Ribbon delete and intake. I just don't know what to get as for intake since everything I see is for jet skis. I am going to run it this summer with just the ribbon delete and air intake. The following summer I might want to try the riva 310HP kit.
GreenHulk has a video out about putting a screw in the SC so the plume won't shake loose and damage the internal blades.
As for the Riva 310HP kit. GreenHulk also has an option of just changing out the internal blades and have a boost of 17lbs compared to the 6 or 7 stock. I do want to try and be as reliable as I can but still have some good improvements.
How much play is there in the wheel usually.
Is there is anything that can help with cavitation while turning hard?
