EastonRob
- Tred Avon River, MD
- FSH Sport
Yesterday I was out in the Bay (beautiful day, but no fish, alas), and I had a temporary loss of power/thrust from the starboard engine. I imagine I had a temporary impeller blockage, but since I've never experienced this before, I wanted to get feedback from the collective here. Here's the basics of what happened:
Boat ran great/normal for quite a while while we tried a couple of fishing spots. Motored over to another spot, our last attempt to find fish, and moved at idle speed through the group of other boats also looking for fish in vain. At this point, we decided to punt and head home, and so I gunned the engines. Up to about 3500 RPM everything seemed ok, but then it didn't sound right above 3500, and I wasn't getting the power I'm used to. I backed off, tried again, and same result. I shut off the engines and opened the clean out ports. I've had to clean grass out of there in the past, but that's about it. I couldn't see anything in the ports, and putting my hand down there didn't yield anything. I isolated the issue to the starboard engine based on the noise and lack of power, and I thought maybe the reverse gate was stuck in position or something.
I tried accelerating again. In throttle sync mode, I noticed at about 3500+ RPM that the starboard engine RPM's would surge slightly higher than the port, rather than staying synced to port, like there wasn't a load on that engine. Anyway, at some point just running around 18 to 20 mph something cleared up. Noise sounded fine again, power was returned, and all was good all the way home.
So, does this sound like an impeller blockage? I guess running at speed finally cleared it out if that's the case. There is a fair amount of debris on the water surface now (e.g., leaves falling from trees). Whatever the object was I guess it couldn't have been that big.
