2015 Shorlandr Leaf Springs
n8dogger32
Merritt Island, FL
I need help finding alternative to Shorelandr leaf springs 4610048 . They are 25 1/4" and have single eye one side and open eye on the other. I need 4 and the ones I can find are around $150 a piece. I just can't seem to find something similar on etrailer. Anyone replace the leaf springs on the trailer for 2015 242?
VitaminSea
Central FL
About 2 years ago I had my 2012 21footer Shorelander trailer serviced by David’s Trailers here in Orlando. I had the leaf springs replaced, as well as all the U-Bolts.
They appeared to have a rather large inventory of parts - maybe give them a ring?
FSH 210 Sport
Tranquility Base
Floridaman79
Brevard County Florida
FSH Deluxe
I just bought 4 of them from bents rv. They were significantly cheaper than anywhere else and i got them the same week.
n8dogger32
Merritt Island, FL
Damn still $110 a pop. Seems steep per leaf when you need 4. Plus the middle mount thing (not sure what it's called 🤣)
Edit* see you called them equalizer bars
n8dogger32
Merritt Island, FL
@Floridaman79 I'm also in the Florida salt water. What material did you go with for the hardware. Galvanized hardware to go with the galvanized trailer?
FSH 210 Sport
Tranquility Base
Floridaman79
FSH Deluxe
I am doing a whole trailer makeover as we speak. The problem is we wont know if it works for another couple years!
I will do a write up on it on what I did and what I liked and didnt like about it.
Dixemon
Low Country Ga.
My disc brakes only lasted 2 years, calipers, pads and actuator all rusted to shit. Despite relentless rinsing with salt away at the ramp, and hose ay home.Rebuilt them last year with all stainless. I couldnt find a stainless actuator though. I soaked the heck out of it with lps3. Do yourself a favor and soak those springs in corrosionx hd. I put it on with a paint brush.
n8dogger32
Merritt Island, FL
I was on my phone before but now I see you're local. Hi neighbor! For the equalizer, did you happen to get this kit? Shorelander 6238600 C-Hook Style Tandem Suspension Kit
Nothing about it says stainless or galvanized or anything of the sort? It would be nice to get a kit like this plus the ubolts and leaf springs and just call it a day.
Floridaman79
FSH Deluxe
Thats the kit but I got it from Eastern Marine and recall it was a bit cheaper. Part number 6238600
It is just zinc plated steel. I coated everything with inorganic zinc prior to assembly, hopefully it will hold out longer.
Floridaman79
FSH Deluxe
My calipers and brake lights only lasted a few months!
Edit - Ok I lied, I just pulled up the history on the calipers and I replaced them at 15 months
Thermobrett
Lithia, Florida
SX195
The brakes on my trailer didn't even last 12 months before seizing completely and I do the same thing, salt away, water rinse and even scrub the trailer after each use. Saltwater is a nasty Mother......
I_squared_r
Colombia/New York
I went through the same thing during the Summer. I needed the same spring. Unfortunately you have to use the shorelandr springs. I tried ordering some springs, Dayton US-2016, they fit, but they were questionable so I returned them and waited for the original springs. I ended up ordering them from a small local shop who was very knowledgeable about Shorelandr parts and informed me that the price of parts has increased a lot since 2020 (something crazy like 2-3x the price). My springs get dipped in salt water a lot so I sprayed WD40 on the springs, to get the grease between the springs, and then coated them with marine wheel bearing grease.
n8dogger32
Merritt Island, FL
I ended up buying the Shorelandr's as well. Easy install but man we had a blast removing the old stuff....
