Thermobrett
- Lithia, Florida
- Boatless
- SX195
At least they put the fenders out….
The other thing that is strange after seeing this last picture is that the truck and trailer is all the way to the left...... along with the boat fenders being on the left in the picture. Almost like they were going to load the boat without the engines and pull it to the trailer with the dock lines.
Looks like the wrong trailer for the boat...
That was my initial thought as well. Almost looks like somebody hammered their throttles by mistake and the boat took off towards land. I dont think the boat has the thrust needed to get to where its at in the pic without a good running start.
Tie off trailer so it can go into the water 10-15' and then use a water tow boat to drag the Yami back into the water. Probably need a tow truck to winch out the trailer. Could use a tow truck with a snatch block hung off of the end pier and winch the Yami back into the water that way. Many ways to skin the cat here.Good observation on the trailer, What do they do next to not cause more damage ? Disconnect the trailer pull the truck away or have another boat pull the boat back ? the trailer would most likely roll back into deeper water if not tied off
If you were loading under power you would have the truck and trailer in the middle of the ramp to have a little maneuvering room on each side.
One thing is certain..... that's going to leave a mark.... or two!
Here is my take on this as there are some telltale signs in your observation.
Newer boater (pretty new boat model) comes into the landing thinking their partner backed in and the trailer is ready. Gets close and realizes it's not their truck and trailer, panics and hits the gas in forward, instead of reverse. Hammers the left guide post of the trailer hard enough to shift it to the right and winds up on the concrete landing next to the truck.
Go back to the first photo an notice the left guide post was impacted hard. Hard enough to bend it over and shove the trailer to the right. We all know that is not the proper trailer for that new of a boat, nor enough truck (debatable). My guess is the captain realized that at the last second as well, and hit the wrong direction on the throttles.
