HangOutdoors
- Royal Oak, MI
What is the Kw sticker on the 1.8L's ?
NA 1.8 is 118kw/158.2hpWhat is the Kw sticker on the 1.8L's ?
Go into the app and select the different colors and take note of the color of the interior with the different hull colors.Ok, so y’all have mentioned interior colors but I dont see anything on the Yamaha site when you go to “build” your boat. Not much to select but accessories. How do you find out what interiors are available and how do I find pictures of them?
Two exterior colors and two interior colors. You can't choose anything else. And each exterior color has an interior color that can't be changes. So you get 1 of two choices per model.Ok, so y’all have mentioned interior colors but I dont see anything on the Yamaha site when you go to “build” your boat. Not much to select but accessories. How do you find out what interiors are available and how do I find pictures of them?
500 hp sounds better than 494 hp doesn’t it?NA 1.8 is 118kw/158.2hp
Supercharged 1.8 is 184kw/246.78hp
From Green Hulk back in 2017
184 kilowatts is the rated nameplate engine power.
Which is 250 metric horsepower, or 247 British/Imperial/American horsepower.
It possible that Yamaha is modestly underrating the nameplate kilowatt engine power to appease insurance or regulatory requirements in certain regions.
Note that marine engines are allowed to be up to 10% more or less powerful than the advertised/labeled number.
So that 184 Kw rated motor might actually deliver plus or minus 18 Kw.
(Looking at the upside, 184 + another 10% = 202Kw, which would be 270 hp
Sorry….. all I was looking at was the fsh models and if you go through the different models you cas see the cool and tan interiors..Ok.. downloaded the app, been on the website and have not seen a single thing that shows any, regardless of hull color, what the interior colors are or even available.
what am I missing?
don’t mean to be difficult but just find it strange
It would be a different story if there were options, but as mentioned, the interior color is matched up with the exterior color at the factory. And a person does not order a color combination from the factory. Folks are putting a deposit down on an allocation of particular colors that the dealer may be getting in. Nobody truly places an order with Yamaha.@VitaminSea
they don't even mention interior colors/options on the website
Confirmed. My 2024 255xd has underwater lighting under the rear deck.Just going by the Yamaha website, it looks like the 22ft models 222S and above and 25ft models 252S and above all have factory underwater lights. Can someone with a 2024 model confirm this?
