I got a 2024 AR250 in yesterday and was able to get it out on the water today. Here are my impressions of the new motors:
- The engines definitely have more power than the previous 1.8. It was very noticeable on take off and in the mid range. We had two full size adults on board and hit 51 mph. There was no cavitation on a full power take off from standstill and the boat really hooked up well. I'm very pleased.
- Noise wise the boat is certainly quieter. At 30mph I was able to hold a normal level conversation with my tech. Of course there's still wind noise but the drone of the engines is significantly less.
- Vibration levels have been drastically improved and honestly that was my and my tech's biggest take aways from our outing this morning. There was not rattling throughout the boat and the steering wheel and throttles felt absolutely solid and still. It really feels like an entirely different boat.
I didn't do much efficiency testing but with a full tank of fuel and 2 large men aboard we were getting just 12.7gph at 29/30mph. Not too shabby. Happy to answer any questions so fire away.
In the video posted above, the two guys were talking about the 4° Less overlap in valve timing, and how that should create a smoother running engine at idle, above you mention, “vibration levels have been drastically improved”, did you notice the boat idled more smoothly and quieter as well as at cruise?
Do you think the four bladed impellers contributed to reduction of vibration at cruise?
That’s all great news about the new engines and we appreciate your first hand observations!
Another thing that was mentioned in the video was the elimination of lead on the Babbitt style bearings. I did some research on this style of bearing, and while there is a very thin layer of lead on top of the copper and tin, and engines with some hours on them one will find that the lead coating on the Babbitt is gone. There are other coatings that can be applied to the babbitt bearing to take the place of lead. Knowing Yamaha I’m sure they tested the new bearings thoroughly.
The boat definitely idles smoother but at speed is where the biggest difference are noticed. I was told the new pump design and 4 blade impeller were a big part of the reduction in felt vibrations. I was also told that the 22' boats see the biggest improvements in all around noise/vibration levels so I'm looking forward o my firs tone of those arriving to compare with.
This is bad news ... once the lead is worn and the copper is exposed the bearing is at the end of life ... if they are pushed beyond this period the engine rod will blow and pretty much toast the engine ... i am familiar with this in the s65/s85 m3, m5 community as many have gotten their bearings replaced with after market as a precaution at a high cost to do .
Regarding the bearing change, “Yamaha will also be transitioning to lead free rod bearings and main bearings for environmental reasons. For those of you that don’t know, lead is a natural lubricant and dampener but highly toxic. Lead free bearings are environmentally safer and are more resistant to corrosion.”
The 1.8s NEVER had corrosion issues as far as im concerned in the last decade they have been out and running .. I also havent heard of any N/A engines ever having bearing issues .. My hunch is the new 1.9s will survive the warranty period, then have issues .. thats when after market will step in ... Lead is the KING of solid bearing material ..
That all sounds fantastic, I was itching to go after the 255 FSH Sport H this year, but maybe I can hold my trigger finger another year and perhaps they'll have SVHO 1.8's in them next year... that would be worth waiting for I think.
Can't find the thread now, but there is a dealer on this forum that shared a little bit of info on testing the new 1.9 he already has on his lot. if I find it I'll post the link here.
from what im hearing ..about 0-30 in .00000000000000000000012ths of a second , top speed 1463 mph you can do bimini run with one swoop of the throttle lever , each way of course !
