210 FSH Live Well
Rei_210
Hello,
any guidance on how to trouble shoot my live well not filling up…switch turns on and has power but it doesn’t turn on at all…no water no sound.
Thanks
dlkhmk
FSH Deluxe
Do you have the intake valve open?
Yammi
Used mine last week and same thing happened….as dlkhmk mentioned, open the hatch cover and there is a quarter turn valve on the right hand side at the top by the hoses.
Rei_210
Yes it’s open…when I turn it on it has zero noise usually you can hear the pump kick in.
Dixemon
Low Country Ga.
the fist year mine went out. It is a Tsunami pump that you have to access through the cleanout tray area. you may want to reset the breaker and try again, then get access to the pump, turn it on again to see if you can hear it, take it out and inspect to make sure it didn't suck something up.
FSH 210 Sport
Tranquility Base
