No spark to either engine
joe coleman
LX
Thanks Dennis
The boat is at the shop but I'll forward the intel to the mechanic. This has to be the answer. My "fix" for joining the two brown wires together must only have bypassed the starter switch and not the ignition switch and now that they are not touching at all, the ignition is not engaging.
HOPEFULLY.....
I'll post whatever the mechanic finds once it is solved. You would not happen to know how to bypass BOTH parts of the hatch switch would you?
I could run down and try and fix it while it is waiting the two weeks at the mechanics shop.
TeenGee
Florida Space Coast
With the hatch open the Hatch Interlock Switch provides continuity between Terminals b (3 Black) & c (4 White) which kills the spark and no continuity between e (1 Brown) & f (2 Brown) which inhibits the starter.
To start and run the motor with the hatch open disconnect all the wires from the switch. Connect the 2 Brown wires together and make sure the Black and White are not touching anything. This configuration will allow the starter to crank and the plugs to fire.
Good luck.
joe coleman
LX
So, in the video I watched, the young man left the Black and White wires connected to the plug for some reason and only wired the two brown wires together.
I'm understanding this is INCORRECT? In addition to connecting the two brown wires, I need to disconnect the Black and white wires, cover them so they touch nothing, not each other and nothing, and then spark AND starter will work?
WOW
OK, thanks for the tip.
Guess I'll make another road trip tomorrow and see if I can work on the boat in the mechanic's "waiting" yard. Afterall, its only a three hour drive each way.....
I'll keep everyone posted.
TeenGee
Florida Space Coast
Well if it was on YouTube I must be wrong.
My understanding of the Hatch Interlock Switch Check and connector diagrams is that:
Connecting the Brown wires will allow the starter to turn.
Separating the Black and White wires will allow the plugs to spark.
joe coleman
LX
Thanks again
I'll redo the fix or should I say I'll do the 2nd part of the fix on Wednesday when are driving by the mechanic and post to the world the results on Thursday.
A GREAT group of guys - thanks all of you.
itsdgm
Thanks Dennis
HOPEFULLY.....
Sorry, but I never had to do that. But it sounds like @TeenGee has provided a possible solution for that.
Hope you figure it out soon.
joe coleman
LX
Well - boat is fixed and I should have listened to you all.
The suggestion for bypassing the back deck safeties was correct. Join the two brown wires to bypass the starter safety and then make sure White and Black wires are isolated to bypass the spark part of the equation.
Mechanic did it and boat runs like a champ.
Thanks again for the help.
craig305
I am experiencing something very similar. Did you notice if you had the key beep when you turned the key?
joe coleman
LX
I did not notice a the "key beep".
I know how to test the engine relay and replace the relay and I now know there are two parts to the back deck safety switch but nothing about a key beep.
Sorry
FSH 210 Sport
Tranquility Base
So
So were both safety switches bad or out of adjustment?
joe coleman
LX
As it turns out NEITHER were bad - but I bypassed them thinking they were and then I bypassed them incorrectly
FSH 210 Sport
Tranquility Base
Okay, then they must have gotten out of adjustment or did you decide to by pas them in the first place and that is what caused your problem?
Kevin C
Maybe you all could comment on my new thread: Crank, no start
Would appreciate the help.
KC
