What did you do to your boat today?
FSH 210 Sport
Tranquility Base
In case anyone is wondering, I installed iridium plugs towards the end of the season last year. They seemed great for the first few outings, but after only few trips, the engines were difficult to start when hot. I installed OEM LFR6A’s a couple of weeks ago, and now it’s perfect. I didn’t even get 20 hours out of the iridium plugs, so I wouldn’t suggest them unless nothing else is available.
Thanks for that report ! I had thought about a fine wire plug… but have a brand new set of the OEM plugs for my boat that I’ll put in at some point. I think I’ve got about 170 hours on the set that are in my boat right now.
Chris D
Removed the damaged keel guard, cleaned up the adhesive & prepping for installation of new one
.View attachment 177310View attachment 177313
Also replacing the wheel bearings on the trailer. Back side of 2 wheels had grease all over them so that told me the seals were letting water in & letting grease out. Cheap enough to just replace all the bearings & seals & not have to worry about them once done.
Which one did you buy? Thanks
Babin Farms
Lower Alabama
HangOutdoors
Royal Oak, MI
Jimmers
55802 Duluth, Mn
I got the N2K code error today on both tacks. I have read through many of the posts regarding this and am still confused. I have a 2012 SX240. Depth gauge, water temp and no wake mode appear to be the only things not working. Will replacing the transducer with the 010-11105-00 fix these? Looking at the posts, it appears that this component is in the engine compartment. Does anyone have pictures showing the location of the installed transducer and the plug connection from a few feet away so that I can locate it? I am not the handiest guy but I do think that I could remove/replace if I new where it is located. Any help is appreciated. Thanks!
Neutron
New Bern, NC
Good luck finding a replacement they are on galactic backorder. It is located under the waterbox in rear most clean out compartment. If you look under the hull you will see the round black part that is on the exterior
mjs5128
Hatfield, Pa
195S
Brought home this little fella over the weekend. 1997 Yammy Wave Venture 760. I’ve never been a PWC guy, but this was hard to pass up. Only has 59.8 hours on it. We personally know all the previous owners and how well it has been taken care of. Should be a fun little toy for our lake/beach vacations. A06B7923-3797-4576-B660-08A9F3CA8B31.jpeg22CB76DE-3149-4DCA-961D-A4F23BD0B236.jpeg
Jdl110
I finished putting seadek in, my audio system, ride steady, trim tabs, swim up seat brackets, docking lights and new aluminum handles on the transom on an AR250
mschulte
252SD
New owner of a 2022 252SD in central South Dakota. We are having a lot of fun, just completing the 10 hour service.
Question on cruise assist....is it correct that only runs off engine RPM and not current speed? I'm finding conflicting reports.
Also, I want to waterski. There is a feature on the boat that let me put in my ride preference (speed, acceleration and name). Yet, I can't seem to get that feature to engage. Anyone else have experience with this? I've searched high and low and can't find any answers.
Appreciate the help!
JBehrens
Huntington Beach, Ca
Yes it's only off engine speed and won't lock in or hold a set MPH. That being said, the 252 has rider profiles that allow for setting speeds on the CONEXT Screen.
mschulte
252SD
Thanks for the feedback.
I got to the rider profile, but had issues with it engaging or going active. Anyone have experience with that?
Chris D
Did you get this figure out? I believe I had the same issue in 2019. The dealer replaced a gauge under warranty.
Jimmers
55802 Duluth, Mn
I have ordered the part mentioned above, it’s on back order till who knows when! For a few hours this weekend, the depth, water temp gauges worked and starboard engine worked with no wake mode. Before I go out again, I am going to tap the transducer under the boat a few times with a rubber mallet. Maybe that can help! I haven’t really figured out how to get to the transducer from the topside and where the wire goes along with what it plugs into.
