NeoBrew
- FSH Sport
Well, I did it. I was on a new lake and passed over a rock “sandbar”. Scuffed up the very bottom of the keel at the back. I can fix that pretty easily with some gel coat.
I also sucked up a fist sized rock into the port impeller. I was amazed that a rock that size could get in there, but it did! The boat seemed to run fine afterwards so I figured I had gotten off easy. I am on a trip right now and when I loaded the boat with gear the extent on the impeller damage was obvious. I have done some straightening and filing to get through this trip, but a new impeller is definitely needed.
Do people recommend the Yamaha impeller or is there a reason to go to aftermarket ones? The starboard one is fine, so I would only switch to aftermarket if there were performance or efficiency gains as I am sure I would want to keep them matched.
I am thinking this is a DIY repair. Doesn’t seem like rocket science. Any advice or links to threads on the topic would be appreciated.
